Cummins12V98 wrote:
ford truck guy wrote:
Yes, that is the Puck system..
I just took delivery of my 1st truck that has the puck system ! I got the B&W Companion OEM for Ford puck Systems.... Just drop it in, turn the 4 handles, and clip them in.. DONE ! ! !
When looking, MAKE SURE the hitch says -
B&W Companion OEM Ford Factory Puck Syatems.... That will be it...
My 20k Companion OEM was part # RVK3300
Etrailer has your hitch RVK3300 at $1,044. The same exact hitch but with stronger base is $1,262 and is rated 25k. Part number BWRVK3305.
I saw that.... If need be, I can just swap out the bases if go larger, but not on this truck
