memtb
Sep 23, 2021Explorer
I don’t see an issue with fabricating a rack......assuming that you have sufficient frame integrity and the weight will not adversely effect your pin/tongue weight.
All of that said......if I have a choice, I would never go propane. Been there - done that ! As compared to gasoline .....propane is very inefficient! You will use much more propane to accomplish the same job. PLUS - gasoline is quite accessible and is a quick/easy fill.....propane - not so much! JMO! memtb
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
