rmoore0852
Dec 24, 2015Explorer
Landing gear maintenance and rebuild questions
Ok, I'll try to keep this relatively short but I have a few questions about the landing gear in my FW. Tried the search, no luck. As I am running the gear up and down I'm getting lots of popping and jumping. I have had this trailer since May. Pretty sure I need to replace the gears. It is making me nervous that one day it will either drop the trailer or that I won't be able to hook/unhook. Previous owner told me that when retracting the gear, he would just let it come up until it popped, that's how he knew it was fully retracted. I have since painted lines on the legs so I don't hit the stops, but I think the damage was already done. I am very mechanical and have absolutely no problem with mechanical work, but first time with this project. Here are my questions:
1. I can't find a label anywhere on my gear. Does anyone recognize what this is so that I can order the correct rebuild kit? I am assuming Lippert, since that is the frame manufacturer.
2. The motor and gear housing wobbles around quite a bit. There are tabs that brace against the tube that stop it from turning. Is this normal or is there a brace or bracket missing?
3. The curb side landing gear has absolutely no access to it. Looks like gear is installed at the factory, then the enclosure for the genset is put in. I REALLY don't want to have to pull the genset and enclosure just to get to the right side gears. There is an access panel on the other side that gets to the battery box and motor leg. I would like to put a matching access panel on the other side to allow both access to that leg and to use that open area as storage. Any ideas on where I can find a matching access door?
4. And finally, what normal maintenance should be done on FW landing gear? I would expect that these things need some grease on occasion, but that brings me right back to the access issue mentioned above.
Give me a few minutes and I will post some pictures.
