gat75's avatar
gat75
Lights dimming and brightening in 5V
My 2010 Blue Ridge has an issue with the 12V lights. While sitting inside RV, lights will suddenly get a lot brighter.
Dimming of the lights is more subtil, seems the dimming of the light is very gradual.
Due to hurricane Harvey, we have been living in this RV full time for the last couple of months. Previously, the trailer was parked at the lake, with intermittent use.
DW & I cannot recall this being a long term issue. We bought this trailer new.
I had installed a new Progressive Industries converter & a new interstate battery a couple of years ago.
I am beginning to be concerned that we may have a short somewhere.
Thanks in advance for you help!
  • Check the 12v system voltage with a meter. 13.6 volts?
    Check the battery for excessive gassing and heat. Also check the water level.
    Then disconnect the battery as the PD converter should run the RV just fine with no battery. What is the voltage now in the fuse panel?
  • We had that symptom when our converter was going out. Not enough umph to charge the batteries and keep all the other 12v running.
