NC_Hauler
Feb 16, 2015Explorer
tcamper wrote:
Thanks guys for all the helpful information.
Just some facts: there is absolutely no difference in the 3500 and the 2500 SRW Ram …… except the rear suspension. The 2500 uses new coil spring technology for a smoother ride (obviously this is the problem) and the 3500 still uses the standard leaf spring technology. Both have the same GCWR, same chassis, same wheels/tires, same tranny/axel ratio, same Cummings diesel…..same everything. Payload on 2500 is 2600 lbs and payload on 3500 is 4100 lbs..
I have driven the 3500 and the 2500 SRW and there is a lot of difference in the ride comfort.
I had fully planned to go with the 3500, until DW did a test ride with me…..and in the new Dodge it was night and day.
I ask the question on this board because I’ve had a few discussions (dealer, friends that have done it and the guys at Kelderman) that all say it works just fine.
If both trucks are exactly the same….except for the rear suspension…..and I lose the new coil spring and add an air suspension system rated at 2700 lbs. each……how does this not get me where I need to be with plenty of room to spare?
I’m really not naive about what is right and safe for my family, just turning to you guys for debate since I’ve done enough research to cause me to ponder.
Sounds like you've already made up your mind...and you post about needing more payload with a Ram 2500...most here, with quite a bit of experience also have made suggestions, but again, just buy the 2500, beef it up some and go camping....'nuff said.....I'd personally want to speak to my wife about what would be more safe, whether one believes it or not, especially if one is wanting to purchase a heavier 5er....
Most of us in here aren't naive either, but simple math and some common sense can go a long way when matching a truck with what one is going to tow. There IS a difference in payload with OEM tires on the RAWR between the 2500 & 3500 SRW truck, but again just spend more money for something to beef up a 2500 suspension....and go camping and forget what most have suggested in here, no matter the experience of others from "learning the hard way"...been there, done that, got the T-shirt...:)
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
