tcamper's avatar
tcamper
Need a bit more payload on Ram 2500.
Needing advice from the pros. I am about to purchase a new Ram 2500 with the 6.7 Cummins. For 2015 the best payload I can get (according to the documentation) is about 2600 lbs. The towing capacity is 17K lbs. and that is more than enough.
We are also considering a new 5er later in the year, and the models on our short list have hitch weight of 2000 – 2400lbs.
With the Ram 2500 I will be cutting in very close on payload. I’ve looked at the Kelderman air system as an after-market add-on.
Will an after-market air system actually allow me a bit more payload?
Are there any suggestions for a particular brand or model?
  • Don't get too stuck on 2500 when for only $600 or so (much less than the cost of a Kelderman) you can get a truck that fits your needs perfectly.
    The 3500 SRW will ride the same and do the job you need it to do.
  • Nothing you can do will actually increase the truck payload. All the mods you are looking at simply help handle the load better.
    You really should be looking at a 3500 SRW for that heavy a trailer.
