- dedmistonModerator
Broccoli1 wrote:
Bumpyroad wrote:
64thunderbolt wrote:
Bumpy, if you are going out dry for a week you better fill it to the brim. If 833# makes a diff you have too much trailer or not enough truck. Mine holds 122 and I fill it to the max every time.
do you have to fill it at home and drive 100/200 miles with that weight or can you just top it off just before you leave civilization.
bumpy
Depends if there is water available where you are going. I fill up so I don't have to worry about looking for water plus I don't want to stop again :)
And time is money. You don't just "top off" 120 gallons of water. If you try to fill your tanks too fast, they won't vent properly and you'll either puke the water back out or crack a tank. Who wants to stand there with the meth heads at the truck stop filling your tanks when you could have done it at home the night before? - GrumpyGatorExplorer
garry owen wrote:
true dat
but then the REAL FS 2800 had 3 axles. not sure if the impostor has heavy duty axles but can see it only has 2
Imposter? LOL! It's just a camper. :h - lincsterExplorer
MLHWINS wrote:
They already went out of business. Unfortunate because I really liked the look of their new trailers. Apparently they have to sell the new ones as used w/ no factory warranties.
Who are you talking about Mark or???? - garry_owenExplorer
Broccoli1 wrote:
28' trailer with 9,999lbs gvwr
Dry weight 7,250lbs ( no generator and no other options)
2,749lbs cargo
160 gallons water $1280lbs
40 fuel station 320lbs
14 generator 112lbs
Generator option 279lbs
758lbs available for Toys and camping stuff :o
true dat
but then the REAL FS 2800 had 3 axles. not sure if the impostor has heavy duty axles but can see it only has 2 - GrumpyGatorExplorer
judelaurenzo25g wrote:
Read this! They are not reviving it, Just using the name. Clicky
Yes, I misspoke. They are just reviving the name. The cool thing about it is, Nexus is building it like a motorhome instead of a travel trailer. Complete steel frame.
I'm not sure if the weights on the website are correct or not. They are only building the 28 and the 26 right now. The two smaller ones will come later. I spoke with one of their salespeople, but he was at a show this week. Hopefully I'll speak with him again next week. - judelaurenzo25gExplorerRead this! They are not reviving it, Just using the name. Clicky
- MLHWINSExplorerThey already went out of business. Unfortunate because I really liked the look of their new trailers. Apparently they have to sell the new ones as used w/ no factory warranties.
- lincsterExplorerThese are not the same trailers as before.
Mark Warmoth restarted under the name Extreme Warrior.
http://extremewarrior.com/ - Broccoli1Explorer
bumpy
Depends if there is water available where you are going. I fill up so I don't have to worry about looking for water plus I don't want to stop again :) - BumpyroadExplorer
bumpy
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
