SMarquez's avatar
SMarquez
Now That We Re-hashed Tires, Tank Repair.
I also found a crack in my water tank when I filled up at my destination. It is right above the cross connector tube fitting, about 1" long. I've never messed with plastic or poly-what-ever-it-is. I can get to the crack without removing anything. Is this better left to a pro or has anyone done their own repairs. Youtube videos make it look doable but I want a long term solution.
  • I found some stuff that's pretty good. WaterWeld by J.B Weld. It's an epoxy putty. It comes in a stick that you cut off what you need and kneed it until it changes color. Sticks to anything, good for water gasoline etc. As mentioned I'd drill a small hole at both ends of the crack....... Good luck.
  • I had a crack on top of one of my tanks that was hard to reach. I patched it with Eternabond tape and it held 3 or 4 years. It eventually got worse and I paid a shop to repair it (drill and weld). Their repair lasted less than a year.
    I think if the crack is bad enough, you're better off biting the bullet and replacing the tank.
  • I fixed mine with a repair kit, specially made for this. the tanks are ABS. You might get by with some ABS glue and mesh.
  • I'd repair it myself - at least the first try. I had to repair my water tank when it developed a tiny crack. The tank was designed with a ledge on 2 of the sides so that it could rest on a supports. Over time it developed a hole from the movement and banging (probably when the tank was empty) while driving. I used a heat gun (it gets soft quickly, so don't over heat it) and some pieces of poly (strips cut out from an empty clorox bottle) which I placed over the hole (crack) and melted into the tank. I then put eternabond along both ledges (as a padding when resting on the supports).
  • I would put a hole at each end of the crack to stop its spread and seal with Eternabond.
