System is working. Worked for a while then I was able to use the manual lever, now nothing. Always reads n.c. Is there a way to check if its the wiring or the unit?
I had a bad plug in the truck bed. It would work then going down the I would get NC. I findly took the truck to a hitch place. It was a 20.00 fix. I tried to find the problem for 2 months
If I'm not mistaken the lever applies full power. So if there was a weak link in the system it would find it. Maybe fried a wire somewhere in the system due to corrosion, worn or loose connection, etc.
I use some contact cleaner on the connections or even WD40 move plug in and out a few time I bet that solve the issue have that brand controler never misses a beat.
