- GMandJMExplorer
Ed9824v wrote:
ok what do you do if there is a piece of the roof missing, my boys trailer was phony fixed with duct tape and coated with a roof sealer and on his last trip is all bubbled up and a big portion of the rubber roofing is missing what do you think is the best fix. I think he should get a piece of rubber roofing and glue it down and seal with eternabond on all sealing pieces and roll with roofing sealer. what you think
You might want to start a new thread and include photos, with something to show the scale/size of the damaged area, if possible. It sounds like it might actually be two problems:
1) cleaning up the phony fix
2) fixing it right/better - Ed9824vExplorerok what do you do if there is a piece of the roof missing, my boys trailer was phony fixed with duct tape and coated with a roof sealer and on his last trip is all bubbled up and a big portion of the rubber roofing is missing what do you think is the best fix. I think he should get a piece of rubber roofing and glue it down and seal with eternabond on all sealing pieces and roll with roofing sealer. what you think
- OkSixpackExplorer
ol Bombero-JC wrote:
OkSixpack wrote:
Misssundowner wrote:
Thank u so much for info on roof repair. We value all of ur expertise
I think the jokes are because you are missing the "u" in rubber.
Jim
"R beer" with a "u" = rUbeer..:?
I only read it about ten times....:o. Sorry O.P.
As far as the repair, I would go with the Eternabond myself probably. It's a little difficult to say for sure without a picture though. Good luck with it.
Jim - Golden_HVACExplorerBeer repair? I was thinking you are going to post a picture of a beer can, cut open and contact cemented to the roof. . Well I would try it.
I actually did use some aluminum foil on my roof, it is still there. I had a crack in the 14 year old EPDM, and to clean it before applying new roof sealant over the opening, I HAD to cover it with something. I had contact spray glue in my worktruck (used to apply fiberglass insulation onto air conditioners and inside the air ducts). So I sprayed on some glue, applied aluminum foil to the area, and was able to wash the roof, and then apply a coating over it, that is still on there.
For a 'reliable' repair that does not look Hillbilly, you might try this stuff. http://www.epdmcoatings.com/videos_play.php?vid=25 This is what I applied to my roof last summer. It is leak free. It goes over all my soalr roof mounts, to the skylights, and gutter to the gutter on the other side. To the fiberglass front cap and rear cap, all one piece.
You can buy a gallon for touch ups, or if the roof is getting close to 10 years old, you might want to buy 8-10 gallons and coat the whole roof - especially while it is still in 'good' condition. You will have no more white streaks! Priceless. White streaks are caused by the factory EPDM roof flaking off to keep it looking like new. After 10 years, most of the white stuff has flaked off, and the black under it is showing through.
For Eternabond pictures and product, check out prices here.
https://www.bigrocksupply.com/Eternabond-RoofSeal-White.html It is really sticky tape, that is waterproof. Many are using it as a really durable product to protect the roof to sidewall connection, that might be rubbed thin by a RV cover or tree encounters!
Good luck on your repair.
Fred. - AllworthExplorer IIYou may get only ten replies, but you sure get a lot of looks from folks trying to figure what the He** you are talking about.
- GMandJMExplorer
Jim
We take our beer seriously, Jim. Would never joke about it. :C - ol_Bombero-JCExplorer
Jim
~ - OkSixpackExplorer
Jim - MisssundownerExplorerThank u so much for info on roof repair. We value all of ur expertise
- jfkmkExplorer
TXiceman wrote:
Beer after the Eternabond repair.
Ken
X2. You might some funky looking repairs if you do the beer first.
About Fifth Wheel Group
19,020 PostsLatest Activity: Jul 19, 2025
