- goducks10Explorer
Jerry B wrote:
Wild Card wrote:
. Three of my four shocks broke off at the lower end spring plate. I took them all off and have noticed no difference while towing. I question the necessity of shock absorbers on heavy trailers.B.O. Plenty wrote:
The shocks on a Heartland product are mounted at almost a horizontal angle. Questionable if they do any good at all. All of mine were bent when I had a Heartland. I don't think they did anything.
B.O.
Useless
On stiff sprung trailers that don't have very much spring movement, shocks probably don't make any difference. - Jerry_BExplorer
B.O.
Useless - Charlie_D_Explorer
Bob Vaughn wrote:
I wonder how many miles shocks on a 5th wheel are good for?
IMO. one never knows. Original on my previous rig had one bent rod. Shock would not move. Two others had lost all function. Fourth would not move. These were original to the rig. Went with Monroe. - Wild_CardExplorer
B.O.
Useless - B_O__PlentyExplorer IIThe shocks on a Heartland product are mounted at almost a horizontal angle. Questionable if they do any good at all. All of mine were bent when I had a Heartland. I don't think they did anything.
B.O. - filrupmarkExplorerI ran the Monroe gas magnums but two of them leaked oil after a few years. I now have KYB KG5514 mono tube gas shocks. I prefer the KYB's .
- buc1980ExplorerDepends of the miles and time .If you get 10 years out of them that perfect.
- Bob_VaughnExplorerI wonder how many miles shocks on a 5th wheel are good for?
- Denny___JamiExplorerThe only way to truly check them is remove one end move them in and out and check for resistance. If you have gas charged units you won't see leakage so even on a vehicle you have to remove them to really see if they are really working, if you go that far just replace them. Monroe Gas Magnums work really good on a trailer,that's what I'm using.
Denny - rhagfoExplorer III
goducks10 wrote:
larry barnhart wrote:
I changed our 2001 alpenlite shocks during the summer. Big difference on the push and pull from old to new. No leaks. I just felt it was time for a change.
chevman
x2
X3
Checked mine while installing the Correct Track, way easier to push pull then when installed. Got new Monroe’s much more resistance the the ones installed.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
