terryaGJ's avatar
terryaGJ
Sub frame addition
Bought a new truck which is over 3" taller than my old one, so I'm getting ready to have a 4" sub frame added to my 2010 Keystone Cougar with 11,000 miles towing on it, to get it level. At the very least I'll have new spring bushings installed. Any recommendations on what else would be good to do while it's all torn apart? Any concerns about going 4" higher on the trailer? Should end up ~13' overall hgt so that shouldn't be a problem. Thanks.
  • No need to buy a shock kit. Just have the welder guy weld some upper brackets on, then buy some U-bolt spring plates that have the angled edges with holes in them.
    You'll need to measure and buy the right length shocks of course. No need for all the $$$ Joy Rider stuff.
  • Look at the MORryde website
    Wet Bolt & HD Shackle upgrade kit
    Brace, Brace, Brace front back and center.
    Look at the equalizer at MORryde and pick one you like.
    Shock's would be really good. I put Joy Rider on mine. You can find less expensive kit's. Lippert and Dexter make some.
  • have you though about installing shorter rear lift blocks on the rear of your truck? I just did that to mine and its still 2" higher out back instead of 3.5" and it leveled out my setup without needing modifications to the 5er.
  • Only 2 across supports?
    What about center shackle for equalizer??
    Should do that also ....lateral/twisting forces when maneuvering
  • Axles have already been flipped. Planing on installing two cross members, in front of the front hangers and behind the rear hangers. Looking at the never fail bushings vs the wet bolt bushings, probably go with the wet bolts. 16's might be in the future, don't want to replace the rims and tires just now, put new Maxxis tires on 3 yr ago so maybe in another year or 2. Thanks for the feedback.
  • Is the axle already flipped? Absolutely wet bolts, a nice addition is a Dexter Eqauflex, possibly longer stabilizers and another step. Some will also go to 16's as part of leveling up.
  • Cross member between the rear spring hanger. Plan on blocks for the jack legs, steps and rear jacks. Raising a trailer increases side load on the spring hangers and torque to the frame. Negate that by welding in a x member between the rear hangers.
  • Cut the spring shackles off
    Weld 2" x 4" tube onto frame
    Weld shackles back onto subframe with bracing and side to side lateral support tubing
    Install WET bolt/bronze bushing set
