bsorroExplorerAug 15, 2014Suburban Hot Water Heater SW10DEI replaced my water heater element and anode rod because we had no hot water on the electric side, had hot water on the gas side before replacing, now no hot water at all and I can't get the water hea...Show More
fishingbob61ExplorerAug 15, 2014Yes, you have to light the oven by hand, as the water heater did you turn off the gas or pull a wire loose when you worked on it?
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???Suburban SW10DE water heaterWater heater issue..Suburban SW10DE DSISuburban Hot Water Heater SW10DEElement for suburban sw10de water heater
