kuziwk
Jul 03, 2019Explorer
SuperLube Axles
Hi Guys, i have a winnebago 27rls (2016 Model). Everything i read said not to use the superlube axles feature as you run the risk of getting grease on your brakes.
Its been about 10 years since i last packed bearings by hand. Is there anything special with the super lube axles that i have to know before i take them apart? Im assuming i can just pull the wheel off and the drum and i should have access to the bearings that way? Also should i replace the seals?
My next step is to see if i have any paperwork on these axles to find the part number of the seals.
