pharmafrog's avatar
pharmafrog
Temperature in the garage
All,
Getting ready to make the change to a TH from a regular 5'er. Wife is very concerned with the temperature regulation in the garage when used for living quarters. Our 5'er sucks for temp in the back room.
We are looking at Heartland, so that may be a stepping off point. Probably going to go with the 3rd ac so cool won't be a problem. But what about warmth in the winter, if used for skiing. Is there insulation for the floor in the garage? How does the non insulated back door affect the temp as well. Thanks in advance.
  • My furnace is about 2ft from the garage. Used the knockout on that side and ran a vent line into the garage,also put a deflector on the line so I can heat it up faster than the rest of the TH.The floor is not insulated so I put a shag carpet down before we make it a play/bed room for the grand kids.
  • We have Raptor 4014 and the garage is hard to keep warm so we have a little electric heater we us if we want to keep that part warm. I think if the heater thermostat was closer to the garage it would stay warmer. the thermostat is in the front part of the living area so it reads the heat up there and turns off before the garage ever gets warm.
  • With one AC in the garage and one in the bedroom all centrally ducted together, I have no problem keeping any part of the Fuzion as cold as I want to in 100 degree ambient temps. In my opinion, heating the garage area is where the toy haulers are lacking. Our garage AC unit has the heat strip in it which works fine in 50 deg weather, but isn't a huge help when it is freezing out. The furnace only has one duct to the garage which doesn't receive much flow because all the other ducts are closer to the source and bleed off all the pressure. If I block the bathroom vent, I can heat the garage satisfactorily. Our last trip out in late October we saw night temps in the low 30s. We had a small electric heater in the garage and were able to maintain 70+ with little effort throughout the trailer.
