therink's avatar
therink
Undersized axles?
I have a Keystone Sydney 340fbh fifth wheel with 5,200 lb axles ( 6 lug wheels) 12,400 gvwr, dry weight of 10,600, leaving payload of 1,800lbs.
If I calculate 20% of Gvwr on the axles, the Gross axle load should be 9,920 or 4,960 per axle. Isn't this cutting it close. Also, I believe 1,800 payload is quite weak for a fiver this size.
Opinions?
