09KZMXT266 wrote:
Stevepro172 wrote:
+1. I can do it myself as well just goes much better with one person on each side.
I have a question for you guys that bought the XTR. How big is your black holding tank? Livin Lite publishes 13 gallons. After two days with 4 people mine was full. Look under at the tank and it says 10 gallons right on it. Also my spare is not the same exact size of the 4 that are mounted on it. After a little research I find this is common?!?!?! Any thoughts as to why?
Steve
I'll have to crawl under to check the spare size next time I go to the storage yard. But, here are the tank specs:
53 gal. Fresh Water, 42 gal. Gray Water, and 32 gal. Black Water Tanks
Mine is also, 53F,42G,32B
My spare is full size, 225R15 I opt for a crank up.
Just put in some rubber floor tile that will soon be covered by a throw rug. I find the bare floor too tinny, the rubber is a great sound/heat insulator, turned on the AC in 90 degree day and it was actually cool inside the trailer.
Don't have to worry about denting the floor with the rubber down.3/8" thick.
Pix soon.
