Pete_Peterson
Sep 28, 2015Explorer
waste water holding tank(s) inspection
2004 HitchHiker II LS (34.5 RLTG)
Three tanks; Solid (black) toilet waste, Body (grey) shower & bathroom sink waste, and Liquid (grey) kitchen sinks waste.
Problem is kitchen sinks (Liquid tank) but I'm a'scared its going to take some work as I had a plumber snake the sinks line to get'em running but by end of next day they took an hour for 1/4 full sinks to drain. :(
I've got a small hand hand cranked snake.
Opinions on whether or not the blockage can be cleared with my little snake?
I'm not going the call a plumber a second time! This will be a do-it-myself caper.
Also water is dripping out from above the under-belly debris shield at a seam aft of what I assume is the cross member for the frame to step up to the bedroom floor level...
Why would slow running sinks cause water to rise to where it would run. There's a vac breaker under the cabinets behind the sink plumbing. Took it out - inspected- functional - air only goes one way. There must be an overflow pipe out'a sight somewhere. I'm guessing it's location can only be determined by pulling down the debris shield. :h
Also the open/close valve handles have broke free of the I-Beam anchors thru which they penetrate to the valve actuators at the tanks. Additionally two of them won't move. :M That should be repared. So, I have some reason let those shields down.
fun fun fun . . .:
Any comments will be much appreciated.
fun fun fun . . .:
