edtoy3's avatar
edtoy3
1985 holiday Rambler Kohler 7cm21
Hello everyone
I have a 1985 holiday Rambler with a kohler generator that does not work! When the generator worked it would power the rear air-conditioner! Is there a way to separate the wiring from the generator to just make it a pig tail and to plug into an outlet 20 amp outlet for the rear AC?
Thanks Ed
  • I sent you a PM on how I did it same generator.
    As mr wizard said.
    But yes an electrician can find the wiring and do a break out to a box with An extension cord so you power the rear unit, or maybe install the selector switch if you don't have one
    My advice get an electrician and show him this post
    Do not try this your self
  • I think you mean with generator you could power either a,/c unit
    And on shore power only the front a/c works
    And your generator has quit working
    And you want to power the rear A/C
    And that comment about whether plugged in or not
    Makes me think you used to start the generator to power the rear a/c while still be plugged into shore power,
    If true, could be what killed your generator
    Some RVs came with a switch that would let you choose to power the rear or front a/c
    It might be in the closet, or in the electric Bay
    You should have started your post
    With i have two a/c unit, but the rear only works on generator and the generator died
    That much more clear
  • With mine you have to take the 50 amp plug out of the wall that it is plugged into ( generator ) and plug it into the cable that feeds the motor home.
  • Thank you for responding! The HR transferswitch is the shore power or generator being plugged in. When the generator worked the rear ac worked whether I was plugged in or not. I guess what I should find out is once power leaves the generator how was that ac automatically powered? Is there a wiring schematic from the generator to the house?
    Thanks
    Ed
  • Maybe I don't understand your question.
    Does your HR have an Automatic Transfer Switch?
    Or do you unplug the power cable from the generator when you connect to shore power?
    If you unplug from the generator to plug into shore power, that will connect all your 120 volt appliances.
    Maybe a previous owner modified/altered the wiring?
