coachellacanuck's avatar
Feb 21, 2018
1988 Ford Lazy Daze with 97 km: too old?
We are snowbirds in need of an inexpensive Class C to make the trip between Alberta and California, south in October and north in May.
Came across this one and here is what I know about it from the Craigslist listing.
26 ft long
V8 5.7 L engine.
Automatic
•replaced the front tires and two back tires
•installed a new brake hardware kit
•replaced the valve system
•rebuilt the tire pressure monitoring system
•balanced the wheel spin
•installed a new water pump
•new starter with life time warranty
It’s $3000.
The current owner is the third owner and bought it to remodel so the flooring and furniture has been removed which is ok by us because we want to remodel as a mobile office.
I have to think it will get about 10 miles per gallon. How does that compare to newer Class Cs, do you think?
I would have it inspected mechanically but I’m wondering what problems these units may be known for?
As always, thanks in advance for any advice
  • That's an excellent brand, but I doubt you will see anywhere near 10 mpg, as the 5.7 is way undersized/underpowered, unless you drive 55, plan on 5-6 mpg.
    That said, the 5.7 is arguably one of the best engines Detroit has ever produced. But... you are talking about a 30 year old motor home, and sight unseen, it's really impossible to tell whether it's a great buy or a money pit.
  • The big question is how is the roof? Roof leaks are the big killers of all RV's water gets in, spreads far more than one would think and causes rot which is often far more extensive than the small stains that you may see inside. As a rule of thumb if you see ANY water spots on the ceiling walk (run) away. Many class C's have leaks around the over cab bed windows.
