Aintright
Apr 02, 2015Explorer
tommykelly wrote:
If you tow with rear wheels down (turning) you either must disconnect driveshaft or keep the engine running.. otherwise you will destroy tranny.
there is no lube with engine off...
unless you are going a "very" short distance
Thanks, guess I will remove the drive shaft and have it towed. They want $150 an hour to remove the drive shaft, it should not take that long, I remove it. the tow truck driver said when I remove it, I must have one of the back wheels off the ground or it will twist on me, break or hurt what ever it hits. :-)
Thanks again for the info.
38,763 PostsLatest Activity: Dec 05, 2025
