MrWizard's avatar
MrWizard
Moderator
May 26, 2019
1996 Ford F53 fuel line quick connects, what size ?
the fuel filter in mounted on the inside of the drivers side frame rail uses quick connect fittings
i want to add an inline fuel pump at the output side of the filter to boost fuel pressure to the engine EFI system (yes its low)
i don't want to cut any fuel lines
i want to couple the new pump into the system
if i can find a pump with the correct male ends
One piece of new looped fuel hose with female quick connects
will couple it all together
additional wiring from the fuel relay is of needed
  • a: i have the hose tools, i changed the filter
    b: yes root cause is the 'IN TANK' pump
    c: yes high pressure inline pump, yes i saw pumps that would do over 50gal an hour aka 244 to 300 liters per hour, some had pressure up to 120#
    d: don't want to cut the lines, prefer to fine pump that will connect to ONE line the existing line going from filter output to front
    and couple filter output to pump input, or pump out to filter IN
    and use one 'connecting hose' between them
    thats why i want to know the 'size'
    when i get out of this wet from rain dirt and onto solid pavement
    i'm going to take a look for space above the tank,
    between gas tank and bottom of RV
    apparently on some MFG, they have raise the floor enough, that there is about 7 inches of space, and some people have been able to remove the FORD OEM in tank pump and replace it, without dropping the 74gal fuel tank
    an option i had Not before considered possible
    i don't think there is that much clearance above this tank
    but i will check
  • The fuel system is designed by Engineers who actually know what they’re doing. If your fuel pressure is low after you replace the fuel filter with a new one, there is something else wrong.
    It could be a bad fuel pump, a clogged pump inlet filter, a crushed fuel line, or a faulty fuel pressure regulator allowing excessive fuel to flow back to the tank.
    You should focus on finding the root cause of the problem before you fix it.
  • When I installed an inline pump on our previous '95 F53, I cut the fuel line just to the rear of the filter and partially bubble flared the cut ends for a firm hose seal when clamped. I used high pressure fuel hose of course.
    I hope you understand the capacity of external pump you need.
    The pump should be rated for a minimum of 60 PSI @ 30 gallons per hour.
    Richard
  • You need the 3/8" fuel line release tool. In kit form it's blue in color.
    Available from Amazon.
    Richard
  • connectors are NOT plastic
    they are metal
    the need a special insert sleeve tool to release them
    little round doohickey with a raise 'flange'? that pushes into the fitting to release it
    this is my fuel filter
    the chassis is 1996 F53 mfg sept 1996,
    RV is 1997 Bounder mfg feb 97
  • I know on the Mustangs the fuel line is 3/8 and the return line is 5/16. I only mention Mustang because I know that one for sure. I would assume that the trucks also use the same sizes.
    Ford part numbers
    Barbed fuel filter fitting 3/8 inch (N806796-S190)
    Barbed fuel filter fitting 5/16 inch (N806187-S190)
    Amazon fitting
    Link to Amazon fitting
  • Fuel line is 5/16". Mine just has plastic clips that pop off and the lines pull out of the filter ends.
    Good luck getting it put together without cutting a line.
    The popular in-line pump add on is referred to as the Dirtrod mod. Documented years ago by a member called Dirtrod. I think I have the info saved as a PDF if you want it.
