Oldgypsies's avatar
Oldgypsies
1997 American Eagle vs 2000 Safari Zanzibar
Hi, we are just starting our full timing journey. We have been sitting in the same park basically for a year waiting for our house to sell.We finally have a contract-so we are thinking about the future. We are 60 and 61. We have 2004 dodge diesel 1 ton and 39 ft 2010 heartland landmark. Eventually we will want/need a class a. This week we have met 2 couples in their 80's needing to get away from rving. The 2000 zanzibar was owned by this couple since it was a year old. Needs a couch. 300 cat and tons of cabinetry upgrades. Would offer maybe $30,000. The 1997 American eagle has 325 Cummins with 147,000 miles. It will come with 2006 subaru Forrester and maybe around $42,000. Any advice on what to stay away from? We are going backwards on years...will parts be available? Will maintenance cost us a fortune? Are we nuts for even considering something this old? Ideas and opinions are very much appreciated. Sorry about paragraphs...on my phone!
  • I don't think either one will bee hard to get parts for
    Everything engine, trans, etc..is of the shelf bus or truck parts, except the "torsilistic" suspension
    And it's ALL heavier and costs more than the parts on your current tow vehicle
    We have a 1995 Safari , with Cummins engine
    Front brakes pads, rotors, calipers, labor total $1378
    Two new front tires $800
    Rear brakes pads, calipers, one rear seal, NO rotors $1178
    Yes diesels can be expensive
    I will say. That things last a lot longer, we have had this RV almost five years, and last brake service was several years BEFORE we got it
    I know the tires were about 7 years old
    It's a matter of being prepared to pay the larger sums knowing, it won't happen again for a few years
  • Well as far as dollars and cents. The American Eagle makes sense. You are getting a good engine "Cummins" (I wont argue on the better engine here-I will just say we dont get too much repairs on either engine, but IMHO the Cummins seems to have more "pep" than the Cat has. And I drive a bunch of Class As every day) ---- Not to mention you get a Subbie to dinghy tow for a small amount.
    As far as reliability, well both are old enough now that the "first year fall aparts" has already happened. It will be hard to get parts for either at this stage. We also get very few repairs on either brand unit. Both are pretty solid.
    Now, look for water damage (possible prior roof damage). Open the slides and look at both outside corners on the bottom (floor) of the slides. That is where most water damage shows first. If the corners are real soft--pass it by! Slide out structure repair is very common, time consuming, and costly. --- Then look at the roof itself. If a roof needs replaced, it can cost from $5k up to $25k (but can be done to look "better than new". --- Finally take time inside each unit. Test all appliances on LP and A/C. Appliances can also be very expensive. Finally run the generator under a load.
    Now if one unit checks out better than the other, buy that one! If they both check out good, buy the one you like better!
  • Hubby thinks air, but that is one of the things we need to learn about :-)
