wdhm04's avatar
wdhm04
1997 holiday rambler endeaver le
Motorhome sat for 2 months started it up yesterday and the instrument lights and daytime running lights were flashing on and off any ideas on what problem might be thanks holiday rambler endeaver le 1997
  • Maybe try turning it off and start again. Maybe disconnect all power including batteries. Make the coach reset everything. Just a thought.
  • When mine is parked in the garage the lights go on and off as a result of being dark then light when the lights are on for a while, in other words this is the way it's supposed to work.
  • I have the very same coach. There is a relay in the front electrical panel, drivers side that controls the day time driving lights. If you unplug the relay it reverts to a normal system that you can turn on and off with switch.
    Bill
