cbgalyon
May 31, 2021Explorer
Still have not found out what our problem is. We have replaced the TPS with 3 different ones, but still get the same thing. The coach will idle just fine and has throttle, but with some white smoke. When we put in in gear, there is no throttle response. There are no codes. We have checked the wiring from the TPS to the ECM, and it checks out good. The check engine light comes on, goes off, then finally stays on solid. This has baffled everyone we have contacted about the coach. Would appreciate some advice on other things we might try.
