JaneNLee wrote:
hi and thanks for your reply.It is a duelthermn, is that made from Domentic? I do not have any switch but off and on on the bottom. The 4 buttons on the front are for up and down temo, fan off anf on. I have called a RV mechanic to cone to help. TY again.
WRONG on the 4 buttons. Here is how you change zones. Doug
The front area could be established as
ZONE 1 and the back section ZONE 2. You can select
the desired temperature and fan speeds for each zone
independently, thereby keeping your bedroom cooler
than the front portion of the vehicle. To determine the
number of established zones in the vehicle, simultaneously
depress the FAN and MODE push-buttons.
Zone 1 will be the first Zone to appear in the LCD
readout. Continue to depress and release these buttons
until you see Zone 1 reappear. Zone 2 will then appear.- JaneNLeeExplorerhi and thanks for your reply.It is a duelthermn, is that made from Domentic? I do not have any switch but off and on on the bottom. The 4 buttons on the front are for up and down temo, fan off anf on. I have called a RV mechanic to cone to help. TY again.
- Do you have the Dometic 4 button wall Tstat that has the LCD screen? If so, it will have 2 zones----zone 1 and zone 2. ONLY zone 1 has the furnace display. So check at the bottom of the LCD display and determine which Zone is indicated. Doug
- JerbirExplorer
dougrainer I have just taken on a 1999 holiday Rambler.Endeavor and and I have figured out the zones but I cannot figure out how to turn on the ceiling exhaust fans. I can't find a manual anywhere. I think I have to use the thermostat, not sure how to turn off the a c and turn on the ceiling exhaust, can you help me?
- way2rollTrailblazer
You are responding to a post that's 6 years old and Doug hasn't been on here since the rollout of the new forum. Shame, he was an excellent resource and very active on the previous version of the forum. I suggest you post your question in a new topic if you hope to get any answers. We have provided continual feedback to lock old posts but there doesn't seem to be any real support on this new forum.
38,782 PostsLatest Activity: Aug 31, 2026
