5952palomar's avatar
5952palomar
2000 Minnie Winnie: Running Board
Does anyone know where I can get a passenger side molded running board..
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post in the RV Forum which corresponds to the subject of your topic. Thank-you!"
  • Winnebago is equipped to provide OEM parts for almost everything they've ever made, at a price, and sold through a dealer. Chances are, an aftermarket E-series running board is going to be much less expensive than having Winnebago run off the OEM replacement part.
  • Lichtsinn Motors in Forest City, Iowa is a Winnebago dealer just a mile or so from the plant. I have purchased several parts from them. They may be able to help you.
  • A 2000 Minnie Winnie is most likely on a Ford E350 or E450 cutaway chassis. This chassis was also used with the more common Econoline Van. If it were me, the first place I would look for a running board would be a local auto recycle yard.
  • Helps if you give more information about the RV, make, model, size, etc. Also have you checked the Winnebago website?
  • You may want to move your question to the class c forum. This forum is for technical help in using the open roads forum
