k9-kenoExplorerSep 15, 20132001 E450 SD Vacuum check valve??Hello...I have a 2001 Ford V10 E450 running my class C and just this weekend we were driving and notice the fan for AC or Heat or vent will go from dash air to defrost when the motor is under stress l...Show More
carringbExplorerSep 16, 2013Its likely more than a bad check valve. You probably had one of the lines eaten by a critter.
Related Contentcheck valve!!Water Heater Check Valvecheck valveswater pump check valveWater pump check valve.
