SNOPRO711X's avatar
SNOPRO711X
2003 Itasca DP does not always start
Last week I got the oil changed on my motor home. On the way home I stopped for fuel. When I tried to start the rig nothing happened when I turned the key. The next time I tried to start the rig it fired right up. It started just fine after that until today. Today it acted up again. About half the time nothing would happen when you turned the key. I checked the voltage at the battery and got 12.59 volts. That seems a little low to me. The batteries are not quite 3 years old.
When it does not start it does not even try to turn over
Any ideas.
  • wolfe10 wrote:
    With a 2003 diesel pusher, he will have the Allison 3000 transmission. No "park". Not aware of one wired to have need for brake application either.
    X2...there is no park and no need to push on the brake pedal. I had the same problem with our coach a couple of years ago. I cleaned all the cables/wires coming from the starter. One of the cables and a smaller wire attached to a 50 amp circuit breaker which I cleaned also.
    I also cleaned the ground wire at the frame(it had a little rust on it). It has started flawlessly ever since. None of the connections looked that bad but they did have a little corrosive buildup at each connection. I guess that was enough to occasionally not allow the starter to turn over.
    I would start by cleaning all your cable/wire connections. Cheap and easy fix if that is the problem.
  • Checked it our again today, it starts on the first try less than 1/2 the time. Most of the time if it did not try to start it will work the next time you try it or if you just hold the key. On a few occasions it took 4 or 5 attempts before it started. If the lights are on they do not dim if it does not start.
    The battery connections checked out ok.
    I am leaning towards a bad ignition switch. Tomorrow I will see what the Freightliner dealer has to say.
    Worn brushes on the starter motor can do that too.
    As can loose or corroded battery cable connections.
    Also burnt contacts on the solenoid.
    Having a meter connected at the starter when it fails can tell you a LOT about what the cause is. IF good voltage appears at the starter but it doesn't run......that's a bad starter.
  • SNOPRO711X wrote:
    It ended up being the magnetic starter relay.
    Thanks for the update. Just curious, where is the magnetic starter relay located? What wires or cable are attached to it?
