eoross's avatar
eoross
2006 Fleetwood excursion 39L LP grill connection
I have the slide out kitchen and it has a gas grill. The LP hose has a male quick disconnect, so where does it connect too? On that side towards the back wheels there is a black pipe with a rubber cap on the end. I assume this is where the connection is made and I need to install the female side of the quick disconnect? Then I would assume there is a valve somewhere with that is accessible? No instruction when I purchased the unit, I would appreciate any help.
  • Well thank you rdmike, I found it! Painted black, tucked up in a dark corner that you get to by sticking your head in the beast. Fantastic I can grill outside now. Thanks again.
  • I will check it out tomorrow afternoon late thank you.
  • Stand at the very end of the sink slide out. Look above underneath. There should be a connection there with a valve connected. Sent me a pm if needed and in the am i can send you a photo.
