rabnud's avatar
rabnud
2006 Newmar essex
pressure washed batterys (as i have done many times) now factory alarm keeps activating and resets itself every time I run or drive it
also when I use the remote system to say set ac temp or switch to heat or try and turn on inverter etc
the display reads "Lack of module"
any ideas out there
  • Moisture in anything electronic can cause weird things to happen.
  • Bruce Brown wrote:
    Would it be safe to assume you have automatic generator start?
    If so my guess would be you somehow unplugged the battery sensor and/or it's full of moisture.
    yes has auto gen start ;;I dont relate that in any way to the alarm going off at random but will certainly take a look see the battery sensor as I understand is a heat sensor and simply shuts off the charging if batterys overheating ?
  • Would it be safe to assume you have automatic generator start?
