rabnud's avatar
rabnud
MAJOR short on a 2006 newmar essex
regarding a 2006 essex any one know what the #293 module is for;; its in the main control system for heat /ac/ gen start/ inverter/ etc etc says module #293 failed
also have a major electrical issue where at the same time the water pump stays on the generator starts all by itself ,the lights flash and the and the main control panel says missing a module #293)
also if u turn the ignition key on the dash lights for the engine controls etc illuminate even though the chassis battery is turned off!! (wont start or turn over though) If u turn the headlight switch on and off everything goes off /back to normal also the brake control flashes and goes off when the headlite switch is pulled on/off as the other stuff
any and all ideas and questions welcome
