- haste_makerExplorer IIProblem was found...it was a quick connect wire end that come unhooked to one of the two fuse blocks on the top of the dash.
- You checked the fuses. BUT DID YOU CHECK FOR 12 VOLT POWER AT THOSE FUSES WITH A VOLTMETER? The Tiffin Monitor and the radio and some other dash systems are supplied from a solenoid that is activated by the key switch when on. This is separate and is not part of the Ford/Workhorse/Chevy system. Doug
38,778 PostsLatest Activity: Jun 10, 2026
