mccsix
Sep 07, 2017Explorer
First thing to do is get your coach weighed at each corner if possible, then go to the tire inflation chart and adjust your tire pressers accordingly. Typically what happens is the service centers will usually fill tires to the max sidewall pressure which will give you the symptoms you describe. 120# sounds too high unless the actual weight and chart gives you that #
