roachcoach's avatar
roachcoach
210 Sealand Toilet
Having a problem with putting my toilets spring cartridge so it will work with the ball valve. After reassembly ball valve will not open or close but it was working before I took it apart. I plan on taking the toilet completely out of the restroom because its to small to work in there. Have the manual but it really doesn't give specific instructions in how to put spring cartridge back together.
1 Reply
  • Had the same problem when I replaced a broken spring cartridge. After close examination, found a hairline crack on the flush pedal. Put the broken spring cart back on the pedal and it would again operate, but had to manually open and close the ball valve with the pedal.
