swhitney's avatar
swhitney
3 position Transfer Switch
I have an older class A RV, I was thinking about installing an inverter but wasn't exactly sure on the wiring.
To me the easiest way if it's even available would be to have a 3 position transfer switch. If I were to be plugged into shore power then that would run everything or vice a versa, if the generator or shore power was not on or plugged in then the inverter would run.
Not trying to power the AC.
Thank you,
Sean
    Thank you,
    Sean
    don't believe there is such a thing, Best to buy a inverter that has the TS built into it.taking a old MH and wiring in a Inverter that
    incorporates the existing system is a big job
