Thanks to all for your insights. I am going to print them out and see if anything works for us. Actually I am only the non techie wife so its hubbie and I trying to figure this out.
We cannot find any transfer switch anywhere.
We are in a visitor spot in a residential park so older pedestal and old old wiring and Maintenance knowing not knowing the difference between 50 am and 30 amp may or may not have anything to do with it.
The coach is getting 30 amps of electric we believe since the load indicator and the electric heater run it up to 30 and does not cut off.
The power supply lites however indicate no power going to the major items such as a/c #2, refrig, water heater are not on as they were for a few days.
Ok here is what I just remembered jeez. This Winnebago Adventurer Model 38T has basement air/heat pump. We were told that a electric heat pump will not work when temp goes below 40. I looked at the lows for this area and that may be part of the problem.
Actually Hubbie got the electric heat to come on in the afternoon yesterday but it would not come on this morning and so it could have been lower than the 46 degrees on accuweather where we are sitting.
Ok so now we have the propane heat on and it heats the bedroom and bathroom but little heat comes out here in the living area.
We move soon to 50 amp so will see what that does?
Of course I called the Dealer who sold me this and he said it worked on walk thru right? lol that will be a new thread and topic as soon as I am done with him. Thanks again.
