Mr.Mark wrote:
rv4jimnme,
The transfer switch is in a metal box usually in one of the bays hanging on the side. It may or not have the name 'transfer switch' on the box. But, don't mess with it unless you are very familiar with electricity (call a professional).
I still strongly think it might be the breaker/breakers on the inverter. If you tried to run too many things on 30 amp, you can pop a breaker on the inverter or a house breaker or maybe on both.
Let us know what the outcome is.
Good luck,
MM.
Mr. Mark,
Sorry to be so dumb but I thought the converter or whatever that thing that is always running usually located under the kitchen stove area and is on all coaches? but on this coach I do have an Inverter and that is on the wall in the off position in the control panel.. because I thought inverter was only to be used when no shore power and you want to run say the microwave or vacumn and it would then draw from house battery. Ours in only 1,000 amp so I have little use for it. Have to get hubbie to help me read these. I appreciate all the help! We have just now sold our home and decided to full time again, and its going to take some getting used to especially with a Coach we are unfamiliar with...
