Couple of suggestions:
1. Get a 12v/120v voltmeter. Learn how to use it. This may sound blunt or snarky but not intended to be. An inexpensive volt meter can save a lot time in trouble shooting. A voltmeter can help trace electric flow from origin to appliance.
2. A converter or inverter can be anywhere. Many are under the sink. Many Inverter/chargers are in a bay. I suggest you get a manual and a person familiar with MH to help ID these things. Once found, check the circuit breakers. Reset them even if they o not look popped. They often don't appear to have popped.
3. Find out if you have an EMS. You can do some simple trouble shooting wothout IDing the EMS. Turn off shore circuit breaker(CB). Turn all internal house CB off. Turn on 1 CB at a time. Save the ACs for last. If something turns on the circuit is good, if it goes off after you turn on an AC, it is probably shedding a load for you, with priority to the AC.
4. Have you set all appliances that can be run on 12v & LP to LP only, such as your fridge? This could reduce the 120 draw and therefore the need to shed.
