wolfe10 wrote:
No question-- HP is a HP. But, how many are willing to run their gasoline engines at peak HP RPM for long periods? Diesels, no problem.
I will:) Boats run these engines wide open all the time, but not everyone is running a 502.
wny_pat wrote:
tinkerer wrote:
the hemi has a lot of power but is constantly hunting for right gear because it's torque curve is small. I really don't care what other say about gassers as I go by the seat of my pants and the diesel wins hands down, JMHO.;)
And there in lays the answer! The torque curve of a diesel covers a much wider RPM range that the gas engine does. The diesel requires less shifting when going up a hill because of the wide torque curve.
The fact is that just the opposite is true. Gas truck engines will have a nearly flat torque curve from about 1800 RPM to about 4000 RPM, much broader than a diesel that won't turn over 2500 RPM. That is why diesels have tons of gears.
Basically you are right but for the wrong reason. What it comes down to is where your reserve HP is achieved. Because of the lower torque of a gas engine, its reserve HP is achieved by turning high RPMs. This means one often must downshift to access the reserve power. In a high torque engine, all of the reserve HP is achieved simply by pouring more fuel into it, without changing the RPM much. This means a diesel gains very little by downshifting.
So to answer the OP's question, quite simply, if both engines are set up optimally, they should accelerate and pull hills very similarly. In other words, if you measure performance by your speedometer, the performance will be identical, regardless of he weight or hill. HOWEVER, because high torque engines have all their reserve power available without increasing the RPM, this means the engine does not downshift when pulling hills. This can make the diesel easier to drive, even though the ultimate power and flat out acceleration is the same.
BTW: The reason diesel is often used in trucks is because of efficiency. The combination of high compression, and self ignition is more efficient than using spark plugs. As a mater of fact, GM and Honda are experimenting with a gas engine that works like a diesel, due to the increased efficiency of the burn. The concept of higher torque is only a design choice, and has little to do with a fuel type.
