JumboJet wrote:
You just cannot comprehend what you read. Apples to apples except for fuel type. That means 3.73 diff in both trucks, 35 gallon fuel tanks both trucks. 25,000 lbs. GVW both trucks. The cruise set at 65 mph - the gasoline would downshift trying to maintain the 65 mpg until the operator just tired of the engine screaming at 5-6,000 RPM. ...
True comparison requires that both engines are operated at their
DESIGNED RPM range. Requiring each truck to use the same gearing makes no sense. No manufacturer designs the same gearing when running diesel or gas. Look at what is commonly used in both chassis. The manufacture is always going to optimize gearing based on load requirements. Gearing that I have suggested has been within the typical
existing chassis designs. (not some radical skew to favor one fuel type) The purpose of the discussion is to compare what a manufacturer would do in a typical chassis design.
Slightly off topic, I've not suggested running my engine wide open for the purpose of comparison, but my engine is unique in that it is built to run wide open all the time, because it was originally designed as a boat engine. In boats, they do tend to run this engine wide open constantly, and it does hold up.
