- ReneeGExplorerWhat we found on 89A is since it's a rolling hil road most of the way, there are a lot of no passing zones. We were stuck behind a slow moving camper, but after several unsuccessful attempts to pass, we decided to just settle in and enjoy the scenery.
- 2gypsies1Explorer IIIHere's a photo of what is left of 'Jacob Lake'. It's basically a deer pond.
https://www.google.com/maps/place/Kaibab+Camper+Village/@36.7092721,-112.2331309,664m/data=!3m2!1e3!4b1!4m5!3m4!1s0x873310bdcac3cc73:0x9e0ebe9f86262863!8m2!3d36.7092721!4d-112.2309422
OP: You can also view the two routes by using Google Map in satellite view. - Desert_CaptainExplorer III"At Jacob Lake you'll be in a lovely pine forest. (no lake here, by the way)"
Actually... there is a "Jacob Lake" we went looking for it years ago and frankly drove right by it without noticing the smallish, muddy pond with a weather beaten sign reading "Jacob Lake".
This was down an old dirit/gravel road and when we saw it after driving another 5 miles before turning around we laughed our butt's off. Might be completely dried up by now as this all took place almost 9 years ago.
:B - harold1946ExplorerYes; Steep downhill after Jacob Lake on 89A. Use lower gears and you should not have a problem.
- JCatExplorer IIIawesome, thanks !
- 2gypsies1Explorer IIIYes they are and many do it.... no other way to get to Flagstaff.
89 is almost flat to Page, AZ. After leaving Page you'll see a truck sign to "check brakes & to use lower gear next 5 miles". The grade down with be a 6% for about 4 miles. There's a runaway truck ramp.
89A - From Fredonia you'll have a easy uphill. At Jacob Lake you'll be in a lovely pine forest. (no lake here, by the way) Then you have a descent down to desert. The descent is around 10 miles of 5-6% with curves. It's a good road. Before the descent there's an extremely wide scenic pull-off on the right. Stop and take in the view! We've done both in both directions. No problem with our 40' motorhome.
38,768 PostsLatest Activity: Nov 21, 2015
