bagman wrote:
It does fit under the hood of the 2017 FORD F-150 and matches up to the OEM transmission. Furthermore, it cranks out 270 HP and 480 ft. pounds of torque. Yeah, I think that 2.7L engine can power a pick-up truck. But what I find totally amazing is that several members here made a reply without watching the tfltruck video at the North American Auto Show! I'm glad that at least Henry Ford had a little imagination, or we would still be running around by horse & buggy!
Fitting under the hood of an F-150 and fitting in the E series chassis are quite different things, On the F series, the engine is in front of the passenger compartment and dashboard, actually under the hood, so it can be the full width of the vehicle. On the E series, it's squished between the driver and the passenger, basically in the dash, and the hood pretty much just gives access to the battery and fluid fills and dipsticks. A boxer engine of any reasonable size would be hard pressed to fit in there; it's inherently wider (and less tall) than a V or inline engine, and we're pretty constrained in width.
The benefits of this engine with regards to fuel economy and power and so forth--or, for that matter, of the German aircraft and its engine--come not so much from the arrangement of the cylinders around the crankshaft as from other engineering considerations and technology. There may be some small advantages in regards to inherent balance etc; I haven't looked up those specifics.
It's not like boxer engines are at all new; just ask anyone with a BMW cruising motorcycle, or a Citron 2CV, or a Piper, Cessna, etc. small plane, or a Subaru car, or.... It's certainly quite possible to construct a van chassis that uses a boxer engine (and VW rather famously has done so). It's not practical to put one in an E series van chassis.
