I took a loss and traded my 3 month old Thor ACE 27.1 for a Winnebago Vista. I wasn't happy about loosing money but I was happy to see the ACE go. I guess that gives you an idea of what I think of Thor's quality. With the ACE I had multiple water leaks, trim pulling off the body, one pocket door pulled off the rollers and jammed blocking the bedroom, and those are just the high points. Quite a few times the house battery wouldn't take a charge and when it did it frequently it would discharge in a couple of hours. Had the battery tested, no problem, it was in the wiring. The handeling was horible; wandered all over the road, bounced around, rattles, jolts, and this was even after an alignment, CHF (cheap handeling fix), tire pressure adjustment, and four corner weighing and load adjustment. If you are go through an ACE just for fun try sitting on the throne. Unless you're over 6 feet, your toes will barely touch the floor.
