Bottom line on ANY AC RV or home if you are getting a 20 degree difference between the room temperature not outside temperature but inside temperature and the temperature coming out of the AC then the AC is functioning correctly. You need to cut down on the heat gain and the size it is cooling for better cooling.
Some tips:
Window tint on ALL windows.
No showers
Use the microwave not the stove.
Cut down the traffic in and out of the RV.
Close off the overhead bunk area and the cab area along with any other areas not occupied such as bathroom.
If you have a awning park with the awning facing west and put it out.
If you have window awnings use them if not some shade cloth with Velcro tabs and matching tabs on the rv around the windows will do wonders. We have a total of 6 1"X 1" tabs for a 40" inch long window three on top and three on the bottom.
Do not let it get hot before you turn on the AC. If traveling run your generator starting in the morning with the AC on so that when you stop you are not trying to cool a HOT RV down.
Ours might be four foot shorter than yours but we have stayed cool in temps over 110.
Would also advise something on the lines of
this.We have experienced low voltage numerous times in campgrounds/RV Parks during hot weather.
