Born_To_Travel
Jul 13, 2014Explorer
The spitter valve is activated when your air pressure peaks and the compressor shuts off.. Do you have a air leak that is causing the pump to kick on and off?.. Block the wheels and take the parking brake off and with the air pressure up do a walk around and listen for leaks..
38,778 PostsLatest Activity: Jun 10, 2026
