Dog_Trainer's avatar
Dog_Trainer
Air dyer update and additional help please (outcome)
I finally got around to looking at the air dryer situation that I posted a week ago.
I have a Haldex pure air (not pure air plus) no spin off filter all inside the canister.
I did look more closely at the air pressure and it is cutting off right around 125 psi ( not the 150 I originally stated)
I did a through check for leaks and as of now cannot find any.
The air will build up and when I shut the engine off it will hold on my guages only losing about 5 lbs in over 1/2 hour.
The purge is about 25 seconds or a little less.
One watching the system work I sit in the drivers seat and watch the gauges they build to pressure then drop just about 2-3 lbs and then I hear the purge another 15-25 seconds and again the purge and very small drop in in air pressure. As I mentioned I can shut off the motor you hear a purge of air but not a significant drop in PSI then the system holds air fairly well.
I put a repair kit in about 4 years ago just for general maintenance
This is the first time it has acted up.
It could be the governor I guess or the spitter valve and seal.
Getting ready for a big trip in the fall so I do not want to have trouble in rte.
Any and and all comments are welcome.
BTW never has had any water in the tanks not a drop.
