rvhippo's avatar
rvhippo
Airstream Avenue - Need advice from owners
I've got a deposit on a used 2011 Airstream Avenue. Airstream claims I have 1525 lbs. available payload on the van (maybe less due to options). I'm planning on towing a trailer. With tongue weight, I'm planning on going up to, but not exceeding GVWR and GAWR-F/R. It will be impossible to get past GCVWR with 11-12% tongue weight on the van (I'm limited more by payload capacity/tongue weight than by max trailer weight).
My problem is: What's my realistic payload rating (I think Airstream calls it CCC (Cargo Carrying Capacity))? Airstream says to check the CCC sticker on the passenger door. Has anyone weighed their Avenue and confirmed the numbers? The dealer keeps giving me strange numbers that don't make sense (this is an out-of-country transaction so I can't personally check it out).
When towing the trailer, I'm planning on putting everything possible back in the trailer. I'll leave 10 gal. of water in the Avenue tow-vehicle for the toilet, but otherwise, it'll just be passengers (500lbs.) and some snacks for the road.
Does any Airstream Avenue owner have their CCC handy? Is that number accurate against an actual weighing? If you could give me some advice, it would be greatly appreciated.
I'm just worried the published numbers are way off from reality and I'll be limited to a tiny trailer.
Thanks in advance!
