- okhmbldrExplorerThose look like stainless steel headers to me. Blow up the photo. It has several places with welds and the tubing doesn't look cast at all. Spray and soak then give them a twist. And don't try to patch with mixed up junk.
- atikoviExplorer
Gjac wrote:
They are cast iron.
I've never seen cast iron formed into tubular shapes like these, especially with that accordion section in the middle like that. - opnspacesNavigator IIAgreed with daily spraying them for at least a week with a penetrating oil. Even if you are going to have a shop do it you might prevent a few broken bolts and the subsequent increase in labor rate.
- GjacExplorer III
atikovi wrote:
. They are cast iron. The newer headers may be SS depending on make. Banks is SS. Thorleys carbon steel and ceramic coated.Gjac wrote:
If you look very carefully the stock manifolds are probably cracked anyways.
I thought they were stainless steel? - Branson_N_TucsoExplorer IIThe poor person that is buying it. Screwed!
- T18skyguyExplorerYou could try JB Weld Extreme heat. Might be worth a shot.
- K_CharlesExplorer
atikovi wrote:
K Charles wrote:
your selling it. Get it hot, mix up some furnace cement, or buy some pre mixed, and but it on the leak. Let it dry before starting.
For a blown gasket?
It will stop the leak. - atikoviExplorerPicture of the other side.
- atikoviExplorer
For a blown gasket? - atikoviExplorer
38,705 PostsLatest Activity: Jan 24, 2025
