mtofell1
Jul 03, 2016Explorer
Groover wrote:
Just my opinion but it seems to me that a few gas pushers were made with the primary goal being to save money and they got carried away with that idea and comprimised quality. Customers then associated gas pushers with the problems and won't buy one now. While I do like my diesel pusher I would like to know how it would perform and how much lighter it would be with a well engineered gas engine and drive train. Gas is so much cheaper now and without DEF a gas engine might actually be less expensive to feed.
I believe that either engine will perform well if properly engineered.
Tvov wrote:BennieH wrote:
"I wouldn't think that would be much of a problem. Diesel engines generally generate more heat than a gasoline engine because of the high compression."
Actually diesels run cooler in the engine compartment. That is why all ambulances are now diesel. There were a LOT of gas engine ambulances that had engine compartment fires in the late 90's and all the builders switched to diesels.
Interesting. I thought the switch was made because ambulances have become so large (F450 and F550 sometimes) and due to constant running / idling.
Constant idling is not good on a diesel.
J-Rooster wrote:bullydogs1 wrote:X-2, I'm one of those stuck with one of those obsolete GM, 8.1, 496 C.I. engines. The EPA knows how to screw up a good working engine! I often wondered if the guy that made that decision owned Ford Stocks?
That cooling issue with the UFO chassis was corrected by a bulletin/recall of it so that's a non issue. There was a cost issue as well, but the 2009 implosion ended the UFO's existence. It actually was a good setup and those that got one you never heard a bad word.
